Design SuiteViewing the drawing by data or by attributes
Vectorworks objects, especially BIM objects, contain a great deal of embedded data and record values that are not always visible or easily accessible, especially for more than one object at a time. Data visualization allows you to see the "big picture" of the data: an aggregate, dynamic view that displays drawing objects based on various data, whether general or specific, according to function, object type, value or range of values, phase status, or any other attached record parameters that you specify. This can be thought of as a graphical or visual report; one data set can be presented in a variety of ways.
Data visualization allows you to override all of the typical aspects that currently make up class appearance. For viewports, select either data visualization or class overrides, depending upon which one is easier or fits the needs of the override best. Data visualization takes precedence over class overrides, but objects drawn normally can still receive class overrides unless Draw Mode for All Other Objects is set to Gray for the data visualization.
Data visualization can be useful when checking for errors, performing quick plan checks, color coding portions of the drawing or sheet layer viewports for final presentations, and more. Examples of data visualizations include:
View space objects according to occupancy, usage, floor area value range, or any other record or parameter property.
Define object attributes or visibility according to the object's status in the active phase, so you can, for example, differentiate among existing, demolished, and new objects
Color wall threshold ranges according to wall height, and locate walls that are not at the correct height at a glance.
Identify materials present in components.
Override a texture to provide an alternate appearance or finish scheme when presenting a proposal to a client.
Show or hide objects in in specific classes to indicate different phases of a project.
Data visualizations are resources that can be saved in libraries, accessed in the Resource Manager, and shared with other projects and people. See Concept: Resource libraries. Multiple data visualizations can be selected for display at one time, or you can group data visualizations that will often be used together and save them as a data visualization set resource.
Data visualizations and sets can be applied to design layers, to saved views, and to viewports on a sheet layer. When a visualization is modified, the modifications apply globally and instantly. Data visualization can easily be turned on or off from the View bar or the Object Info palette of a viewport, to display the drawing with either a data visualization or the object attributes.
Worksheets have image functions that can apply a visualization to an object image, by referring to a saved visualization or to a viewport’s applied visualization set. See Worksheet functions.
Document preference settings for Black and white only and Use layer colors do not apply when a data visualization is selected for the drawing.
Applying a data visualization
Creating a data visualization
Creating a data visualization set
Editing the current data visualization
